Hot Topic (More than 10 Replies) Inplace edit control (Read 7555 times)
Dexter
Jun 25th, 2009 at 7:48am
Hi there!
I want to customize the edit control of a node in a diagram. I have implemented the createeditcontrol event and set the edit control on the event args to the control made by me. I have set the bounds to some values related to the node. In the enter inplace edit mode event handler the bounds of the edit control in the event args if modified, not the one I have entered.
The code in the create edit control:
CodeMaskTextBox control = new CodeMaskTextBox();
           control.Text = e.Item.GetTextToEdit();
           control.KeyPress += new KeyPressEventHandler(control_KeyPress);
           control.LostFocus += new EventHandler(control_LostFocus);
           int height = (int)(e.Node.Font.SizeInPoints * 3);
           PointF mousePosition = diagramView.ClientToDoc(Control.MousePosition);
         diagramView.DocToClient(e.Node.Bounds);
           rectangle.Height = height;
           control.Bounds = rectangle;
               e.EditControl = control;
after this code the bounds of the node is {X = 268.0 Y = 456.0 Width = 60.0 Height = 45.0} and the bounds of the edit control is {X = 357 Y = 607 Width = 80 Height = 21}
at the beging of the method private void diagramView_EnterInplaceEditMode(object sender, InPlaceEditEventArgs e) the node bounds is {X = 268.0 Y = 456.0 Width = 60.0 Height = 45.0} (the same) and the bounds of the edit control is {X = 357 Y = 560 Width = 80 Height = 19} ( the height and the Y position is modified).
please help
Dexter
Re: Inplace edit control
Reply #1 - Jun 25th, 2009 at 10:57am
Hi Dexter,
The node.Bounds coordinates are usually specified in millimeters, and the control coordinates must be set in pixels. I can see DocToClient called in your code, but the result is not assigned to anything? It should probably look like the code below?
rectangle = diagramView.DocToClient(e.Node.Bounds);
Dexter
Reply #2 - Jun 25th, 2009 at 11:16am
Hi!
sorry about that. the code there is like this:
Rectangle rectangle =diagramView.DocToClient(e.Node.Bounds);
it was a mistake in my writing.
Reply #3 - Jun 25th, 2009 at 1:15pm
Is CodeMaxTextBox your own control? If you replace it with a Listbox, does the listbox appear where expected?
private void diagramView_CreateEditControl_1(object sender, InPlaceEditEventArgs e)
	ListBox control = new ListBox();
	Rectangle rectangle = diagramView.DocToClient(e.Node.Bounds);
Dexter
Reply #4 - Jun 25th, 2009 at 1:21pm
Yes the CodeMaskTextBox is a user control of mine.
If i use the Listbox the placement is ok. Do you have any idea?
??? Cry
Reply #5 - Jun 25th, 2009 at 1:42pm
Have you implemented your own Bounds setter? Or by chance Bounds might be set in response to some event raised by a child control?
Dexter
Reply #6 - Jun 25th, 2009 at 2:03pm
no, i don't have any implementation done for the bounds setter. if you want I can send you the control to test it better?
about the other possibility, I do not know what to say. it is plausible but  ??? ?
Regards
Reply #7 - Jun 26th, 2009 at 5:08am
Ok, please email the control to support@mindfusion.eu.
Dexter
Reply #8 - Jun 26th, 2009 at 5:35am
I have send you the control! The mail subject is "Inplace edit control forum thread. For support to Stoyo". I hope it helps!
Regards
Reply #9 - Jun 26th, 2009 at 12:39pm
The control appeared where expected in our test app:
https://mindfusion.eu/_samples/CodeMaskTextBoxSample.zip
Try adding to it the properties and event handlers you are using to see what exactly changes its position in your application.
Dexter
Reply #10 - Jun 26th, 2009 at 1:28pm
Hi Stoyan!
I have send you back an application with an example of what I have. In the application there are 2 table nodes (but the same happens if there are shape nodes). The one at the top of the diagram, the position is lets say ok, but at the one at the bottom is not ok! Take a look!
Regards
Reply #11 - Jun 26th, 2009 at 3:03pm
The custom control changes its position unexpectedly once DiagramView adds it as a child when running in your application, but we could not find any reason why this happens. As a workaround, move the node.Bounds assignment to a handler of the EnterInplaceMode event. It is raised after the control has been added, so setting the position from there works fine.
Dexter
Reply #12 - Jul 23rd, 2009 at 7:05am
Hi Stoyo!
I have some links in my application where the in place edit is not important, so I do not need the edit control. Can I cancel the in place edit sequence for some of the diagram items?
Thanks in advance!
Reply #13 - Jul 23rd, 2009 at 7:09am
You could set AllowInplaceEdit = false, and call DiagramView.BeginEdit(e.Link) in response to the LinkdoubleClicked event, only for links that users are allowed to edit.
Dexter
Reply #14 - Aug 6th, 2009 at 2:17pm
Hi Stoyo!
I see now that is a node is inplace edited and the zoom factor changes the edit control of the inplace edit is position strange. It is a bug or I am missing something. You can test it on the DEMO application.
Best regards,
Dexter
