Normal Topic Problem deleting Object from FLowChart (Read 2849 times)
cenanove
Jun 25th, 2009 at 9:33pm
I have problem deleting object from the flowchart.
Here is code:
              try
foreach(Arrow obj in objectsToDelete)
    if (manager.FlowChart.Arrows.Contains(obj))
manager.FlowChart.DeleteObject(obj);
catch (Exception ex)
string        s=ex.Message;
I have two arrows inside collection objectsToDelete, first one is deleted without problems and second one passes   “if (manager.FlowChart.Arrows.Contains(obj))" but fails on flowchart.DeleteObject with Error:
ex.Message"Cannot remove the specified item because it was not found in the specified Collection."
Could anyone help please?
Thanks.
Enver.
Re: Problem deleting Object from FLowChart
Reply #1 - Jun 26th, 2009 at 5:23am
What is the full exception stack trace? Are you handling any Deleted events?
cenanove
Reply #2 - Jun 26th, 2009 at 3:21pm
This is  exception stack trace?
ex.ToString()"System.ArgumentException: Cannot remove the specified item because it was not found in the specified Collection.\r\n   at System.Collections.CollectionBase.System.Collections.IList.Remove(Object value)\r\n   at MindFusion.FlowChartX.ArrowCollection.Remove(Arrow a)\r\n   at MindFusion.FlowChartX.Selection.x715ab1b7ea8d866b(ChartObject xa59bff7708de3a18)\r\n   at MindFusion.FlowChartX.Selection.RemoveObject(ChartObject obj)\r\n   at MindFusion.FlowChartX.FlowChart.xa456762ceebce31f(ChartObject xccb63ca5f63dc470)\r\n   at MindFusion.FlowChartX.Commands.RemoveItemCmd.Execute(Boolean undoEnabled)\r\n   at MindFusion.FlowChartX.UndoManager.x2bab335568e5c4c6(Command x61b060a94340c4fc)\r\n   at MindFusion.FlowChartX.Commands.RemoveItemCmd.Execute()\r\n   at MindFusion.FlowChartX.FlowChart.x9c02b19c3454013a(ChartObject xccb63ca5f63dc470)\r\n   at MindFusion.FlowChartX.FlowChart.DeleteObject(ChartObject obj)\r\n   at FacT.Library.FlowChartPipelineDeleteManager.FinalDeleteBRN() in c:\\fact_current\\fact\\uiclasses\\deleting\\flowchartpipelinedeletemanager.cs:l
ine 592\r\n   at FacT.Library.FlowChartPipelineDeleteManager.DeleteBRN(Arrow a) in c:\\fact_current\\fact\\uiclasses\\deleting\\flowchartpipelinedeletemanager.cs:l
ine 82\r\n   at FacT.Library.FlowChartManager.DeleteBRN(Arrow a) in c:\\fact_current\\fact\\uiclasses\\flowchartmanager.cs:line 485\r\n   at FacT.Library.ProjectEdit.RemoveSelectionFromTheGraph() in c:\\fact_current\\fact\\forms\\projectedit.cs:line 10856"string
Reply #3 - Jun 29th, 2009 at 1:55pm
Do your Deleted event handlers run any code that changes the selection? What happens if you clear the selection before starting the loop over objectsToDelete?
wushuang83
Reply #4 - Jul 1st, 2009 at 8:16am
you can do it like this:
for (int i = flowChart1.Boxes.Count; i > 0; i--)
delete your object;
you have 2 obj,boxes[0] is A,and boxes[1] is B,if you delete Boxes[0] A,now Boxes[1] B will change to Boxes[0] B.
