Normal Topic link coordinates (Read 1739 times)
zoozoo
link coordinates
Jun 29th, 2009 at 7:48am
Hi..
when i change the size of my user control , the links in diagram do not change accordingly to start from the new center ( coordinated ) of the control.
Is there any way we can make it relative to the control nodes size ...
thanks in advance.
Re: link coordinates
Reply #1 - Jun 29th, 2009 at 10:31am
Are setting the Width and Height of the hosted control? Try setting the ControlNode.Bounds instead; this should update the link positions and also set the control's size.
zoozoo
Reply #2 - Jun 30th, 2009 at 3:30am
thsnks.
Setting controlnode bounds and the link startpoint/endpoint worked.
newnode.Bounds = new Rect(0, 0, 150, 85);
link.StartPoint = diagram.Nodes[i / 3].GetCenter();
link.EndPoint = diagram.Nodes[i].GetCenter();
