Normal Topic Implementing custom DiagramLink (Read 2064 times)
cpmjones
Jun 30th, 2009 at 9:37am
I am implementing my own class derived from the DiagramLink class, called DependencyLink.
I setup my diagram as follows:
Diagram.registerItemClass(DependencyLink.class, "DependencyLink", 1);
       diagramView.setCustomLinkType(DependencyLink.class);
diagramView.setBehavior(Behavior.Custom);
The problem is when creating a link using the mouse, results in:
java.lang.NullPointerException
       at com.mindfusion.diagramming.DiagramLink.startCreate(Unknown Source)
Any help is greatly appreciated,
thanks,
Chris
Re: Implementing custom DiagramLink
Reply #1 - Jun 30th, 2009 at 11:54am
Have you called the DiagramLink constructor that takes a Diagram instance as argument? If you omit this, Java will call the no-args constructor, which is used only for serialization and many fields of the class will remain uninitialized.
cpmjones
Reply #2 - Jun 30th, 2009 at 12:20pm
Hi Stoyo,
thanks for your quick response.
I was only providing the constructor passing the diagram with src and dest nodes also.
After adding the constructor for just the diagram, this now works.
Chris
