Normal Topic Drag drop functionality (Read 1585 times)
zoozoo
Jun 30th, 2009 at 10:04am
i have implemented the a diagram with treelayout. aslo have implemented the drag rop of control noes on the lines of TreeLayout sample. but in my case sometimes after i drop the control node the tree is reconstructed but the mouse appears clicked and on moving it around it selects the existing nodes on the tree..
any halp around this
thanks in advance
Re: Drag drop functionality
Reply #1 - Jun 30th, 2009 at 11:58am
This might happen if the control receives a MouseDown message. Try setting diagram.Behavior = DoNothing when starting a drag operation and restore it to its original value when drag-and-drop completes.
zoozoo
Reply #2 - Jul 1st, 2009 at 2:40am
Thanks Stoyan ! Setting the bahaviour correctly solved the issue .
