Normal Topic Link rendering (Read 2400 times)
zoozoo
Link rendering
Jul 2nd, 2009 at 5:19am
Can i have the links to render in horizontal/vertical fashion instead of slanting ?
how can i change the color and arrowhead of the links ?
thanks in advance
Re: Link rendering
Reply #1 - Jul 2nd, 2009 at 6:52am
Set the Style, HeadShape and Pen properties of links. The link segments for LinkStyle.Cascading alternate between horizontal and vertical direction.
zoozoo
Re: Link rendering
Reply #2 - Jul 2nd, 2009 at 8:58am
hi,
link.Cascading dosent seam to solve the problem.
when we have one parent and two child nodes , the links are displayed as two slant lines starting from patent to child nodes.
but the requirement is to draw only using horizontal and vertical lines.
please advice.
Re: Link rendering
Reply #3 - Jul 2nd, 2009 at 11:56am
If you are applying some layout class, this might change the link style. E.g. if using TreeLayout, set the TreeLayout.LinkStyle property to Cascading3.
zoozoo
Re: Link rendering
Reply #4 - Jul 3rd, 2009 at 4:24am
Thanka ! this works really nice !
