Normal Topic Shape decorations (Read 3356 times)
lyudmil
Shape decorations
Jun 29th, 2009 at 9:23pm
I was trying to create some new shapes with filled shape decoration inside. In order to create the xml for the .shl file I used one of the new BPMN shapes as an example. The problem is that when I save in xml the "BpmnEndCancel" for example I get the following xml:
<shape id="BpmnEndCancel" fill-mode="Winding">
<outline>
<arc dash-style="Custom" width="-1" x="0" y="0" arc-width="100" arc-height="100" start="0" sweep="360"/>
</outline>
<textarea>
<line dash-style="Custom" width="-1">
<point x="-20" y="100"/>
<point x="140" y="100"/>
</line>
<point x="140" y="140"/>
</line>
<point x="-20" y="140"/>
</line>
</line>
</textarea>
<shape-decorations>
<shape-decoration>
<decorations>
<point x="45" y="50"/>
<point x="23" y="28"/>
</line>
<point x="28" y="23"/>
</line>
<point x="50" y="45"/>
</line>
<point x="73" y="23"/>
</line>
<point x="78" y="28"/>
</line>
<point x="55" y="50"/>
</line>
<point x="78" y="73"/>
</line>
<point x="73" y="78"/>
</line>
<point x="50" y="55"/>
</line>
<point x="28" y="78"/>
</line>
<point x="23" y="73"/>
</line>
</line>
</decorations>
<brush Type="Solid">
<Color>#FF000000</Color>
</brush>
<pen>
<Brush Id="0"/>
<DashOffset>0</DashOffset>
<DashStyle>0</DashStyle>
<LineJoint>0</LineJoint>
<MiterLimit>10</MiterLimit>
<Width>0.1</Width>
</pen>
<fill-mode>1</fill-mode>
</shape-decoration>
<shape-decoration>
<decorations>
<point x="100" y="50"/>
<point x="90" y="50"/>
</line>
<arc dash-style="Custom" width="-1" x="10" y="10" arc-width="80" arc-height="80" start="0" sweep="360"/>
</line>
</decorations>
</brush>
<pen>
<Brush Id="0"/>
<Width>0.1</Width>
</pen>
<fill-mode>0</fill-mode>
</shape-decoration>
</shape-decorations>
<enable-outline>True</enable-outline>
</shape>
When I add this xml to my .shl file the decoration of the shape is not visible. This happens with all the shapes with decoration inside. What am I doing wrong? By the way this BPMN shapes are a great new feature. Thanks for that.
Re: Shape decorations
Reply #1 - Jun 30th, 2009 at 8:04am
I can see this shape after loading the library file:
Is that the expected result? Which version of the control are you using?
lyudmil
Reply #2 - Jun 30th, 2009 at 8:29pm
First I want to apologize for posting in the wrong thread. I meant Diagramming for ASP.NET. I am using the latest version downloaded from https://www.mindfusion.eu/NetDiagramTrial.zip. The shape that you attached is exactly what I was expecting, but I got just an empty circle. Any ideas will be helpful.
lyudmil
Reply #3 - Jul 1st, 2009 at 7:07am
The released version of the applet did not have xml serialization implemented for filled decorations. It should work with this version:
https://mindfusion.eu/_temp/applet.zip
lyudmil
Reply #4 - Jul 1st, 2009 at 8:17pm
This works great.
