Normal Topic FlowchartLayout not working (Read 1471 times)
Hamdy Ghanem
Jul 2nd, 2009 at 10:00am
I have this code
   Dim layout As New FlowchartLayout()
                   layout.Orientation = MindFusion.Diagramming.Layout.Orientation.Vertical
                   layout.IgnoreRepeatingLinks = True
                   layout.Arrange(Me.MainDiagram)
                   MainDiagram.ResizeToFitItems(10, False)
but when I run the app diagram will not change
is there any property I set let it not working?
Re: FlowchartLayout not working
Reply #1 - Jul 2nd, 2009 at 12:11pm
FlowchartLayout.Arrange might return false if it cannot find any start node - one without incoming links. If that's the case, you might add a temporary start node and remove it after the layout. Additionally, it expects there is a directed path to each node in the flowchart from some start node.
Hamdy Ghanem
Reply #2 - Jul 2nd, 2009 at 9:20pm
I realize the problem
My node class, I set the property
Ignorelayout to true for all noes while creating
I remove this lin now it works greate
Thanks for help again
