Normal Topic margin on DrawHandles (Read 2169 times)
Luke
Jul 9th, 2009 at 4:28pm
i have override the DrawHandles Method in a CustomNode.
(diagramView.ModificationStart = ModificationStart.AutoHandles)
When i hover over the Node my Handle is drawn ... but when i leave the Node-Bounds where is a margin (circ.10 units) before the Handle is deleted.
How can i modify this Margin to 0 ?
best regards
Luke
Re: margin on DrawHandles
Reply #1 - Jul 10th, 2009 at 6:36am
There is currently indeed a 7 mm zone around items, which is currently hard-coded and cannot be changed. If it is important for you, we can introduce a property to control this value. If you have purchased the source code of the control, you can manually modify this value in the DiagramView.DrawAutoHandles method.
Luke
Reply #2 - Jul 10th, 2009 at 7:09am
sadly, we don't have the source code.
It would be of great help to us when you introduce a property.
Luke
Reply #3 - Jul 13th, 2009 at 6:45am
This version adds AutoHandlesMargins property to DiagramView:
https://mindfusion.eu/_beta/fcnet_autohandles.zip
Luke
Reply #4 - Jul 13th, 2009 at 1:41pm
Great support.
Thanks a lot!
