Normal Topic Adjust shapenodes' text alignment (Read 1190 times)
khstar
Jul 14th, 2009 at 9:06am
For Each p As Mindfusion.Diagramming.DiagramNode In MainDiagram.Nodes
        CType(p, Mindfusion.Diagramming.ShapeNode).TextFormat.Alignment = StringAlignment.Far
       Next
I just tried code above.
But it doesn't affect right away.
When I click or move the shapenode, Then I can see changed alignment.
How can I make an effect right after code?
Re: Adjust shapenodes' text alignment
Reply #1 - Jul 14th, 2009 at 10:01am
The control cannot detect changes made to the StringFormat object. You could assign a new StringFormat instance to ShapeNode.TextFormat, and then the TextFormat setter will update the text layout as expected.
