Normal Topic Parsing svg takes too long.. (Read 2126 times)
khstar
Jul 15th, 2009 at 5:39am
I used to use shape node with bitmap background, and try to move on to SVG node.
I tested some SVG node which has some gradients and simple rectangle.
When I parse SVG's content, It took about 2~3 sec.
(My computer has Pentium E8400..)
After parsing, Creating svg node with parsed content is very fast.
Strangely, when parsing, Cpu usage is low from task manager.
I hope some improvements on this in later version.
Thanks!
Re: Parsing svg takes too long..
Reply #1 - Jul 15th, 2009 at 6:47am
The SVG parsing speed has been improved in V5.3.1; we sent the upgrade links last week.
khstar
Reply #2 - Jul 15th, 2009 at 7:00am
I already use 5.3.1 version. And still takes 2-3 seconds.
I tried SVG node because of bad background image quality when resize.
However I think I found another way.
http://www.glennjones.net/Post/799/Highqualitydynamicallyresizedimageswithnet.ht...
With this link, I modified some functions and Image quality is quite improved.
Who suffered from same problem, refer the link.
Thanks.
Reply #3 - Jul 15th, 2009 at 7:11am
If you select diagramming.dll in solution explorer / references, does it show version 5.3.1 in the properties window? If you have built your assemblies from source code, check if the project references the latest mindfusion.svg assembly.
