Normal Topic Node Position (Read 3210 times)
himaheshh
Node Position
Jul 16th, 2009 at 8:42am
My requirement is to set every alternate nodes at a hight greater than the previous node. Is it achievable?
Regards
Mahesh
Re: Node Position
Reply #1 - Jul 16th, 2009 at 10:33am
Are you placing the nodes in a row, and need every second node to have a greater Height than the previous node?
himaheshh
Re: Node Position
Reply #2 - Jul 17th, 2009 at 12:07am
Hi Stoyan,
Yes, I am adding nodes top to bottom and while doing that I want to set every second node to appear below(not the height of the node but the link height) the previous node.
The objective is to save the space in order increase the usability. trying to achieve something like this,
ROOT NODE
NODE 1 NODE 3
NODE 2 NODE 4
Re: Node Position
Reply #3 - Jul 17th, 2009 at 1:55pm
Do you need that as a modification of the result of TreeLayout?
himaheshh
Re: Node Position
Reply #4 - Jul 22nd, 2009 at 2:22am
Thank you.
Sorry I didnt get your question.However, I need to do this when ever I load the diagram in the screen.
Regards
Mahesh
Re: Node Position
Reply #5 - Jul 22nd, 2009 at 6:18am
Do you need something close to TreeLayout, but with nodes from the same tree level placed on two rows?
himaheshh
Re: Node Position
Reply #6 - Jul 22nd, 2009 at 10:13am
Exactly!
Re: Node Position
Reply #7 - Jul 22nd, 2009 at 12:08pm
Try this:
TreeLayout tl = new TreeLayout();
tl.NodeDistance = 0;
tl.Arrange(diagram);
DiagramNodeCollection nodes = new DiagramNodeCollection();
GetBfsOrder(root, nodes);
for (int i = 1; i < nodes.Count; ++i)
	DiagramNode node = nodes[i];
	PointF p = node.Bounds.Location;
	p.Y *= 2;
	if (i % 2 != 0)
		p.Y += node.Bounds.Height;
	node.Move(p.X, p.Y);
private void GetBfsOrder(DiagramNode root, DiagramNodeCollection nodes)
	Queue<DiagramNode> queue = new Queue<DiagramNode>();
	queue.Enqueue(root);
	while (queue.Count > 0)
		DiagramNode node = queue.Dequeue();
		nodes.Add(node);
		foreach (DiagramLink link in node.OutgoingLinks)
			DiagramNode child = link.Destination;
			if (!nodes.Contains(child) && !queue.Contains(child))
				queue.Enqueue(child);
