Normal Topic Using two versions of FlowChart .NET (Read 1529 times)
David Long
Jul 31st, 2009 at 11:54am
I have a project that contains three executables that use FlowChart .NET 4.3.1.  Due to time/money considerations I only want to upgrade one of them to 5.3.1 at this time.  Is it possible to produce a Visual Studio solution and setup project that allows this?
David
Re: Using two versions of FlowChart .NET
Reply #1 - Jul 31st, 2009 at 1:31pm
It shouldn't be a problem if you install the assemblies in the GAC. Otherwise you could install the executables in different subfolders.
Aziz ur Rahman
Reply #2 - Aug 1st, 2009 at 6:13am
In case you projects (using different versions of mind fusion) are referencing each other, you can use assembly remapping in app.config.
We were having the same problem and we did this.
Syed Aziz ur Rahman
