Normal Topic LaneGrid - Groups problem and Printing problem (Read 4183 times)
David Long
Aug 6th, 2009 at 12:55pm
I have been upgrading my LaneGrid application from 4.3.1 to 5.3.1 and have two problems (so far!)
1. A ShapeNode's subordinate group members are only visible when the MainItem is selected - they used to be visible at all times.
2.  I can't see how to enable printing of the LaneGrid - apparently this feature was added in version 5.
David
David Long
Re: LaneGrid - Groups problem and Printing problem
Reply #1 - Aug 6th, 2009 at 1:33pm
I have figured out the first one - I did not add the new attached items to flowChart.Nodes
Still can't do printing though.
David
Reply #2 - Aug 6th, 2009 at 7:00pm
I've added a button that calls diagramView.Print() to the Lanes example and it worked fine; can you verify that? Note that you must have some items in the diagram; otherwise it is considered empty and won't be printed, even if there is a lane grid shown.
David Long
Reply #3 - Aug 6th, 2009 at 7:42pm
I've done the same as you with the Lanes example and I only get the boxes printed and not the grid.  Not too sure what that means - any ideas?
David
Reply #4 - Aug 7th, 2009 at 9:16am
Seems the last release broke something in the lane printing code. Check the PM page for a fixed version.
David Long
Reply #5 - Aug 7th, 2009 at 9:56am
Many thanks - that works fine.  Smiley
David
TimNZ
Reply #6 - Aug 8th, 2009 at 8:53am
Stoyan,
When you provide private releases to people via PM etc, do those fixes/changes always get merged into the next official release?
Reply #7 - Aug 10th, 2009 at 6:12am
Yes, they do get merged.
