Normal Topic Text in a Box (Read 2439 times)
Henry
Text in a Box
Aug 12th, 2009 at 12:01pm
i must display some text in a ShapeNode, this text is too long to show this in a Node. There are no blancs in this Text an i can't use any line breaks.
The Node dont't diaplay any Text, it is empty!
I think i need a word-cut-methode, better a function wich calculate me the length in px for the Text so that i can cut this Text (with ... at the end).
Is there any solutions for this?
greeting
Henry
Re: Text in a Box
Reply #1 - Aug 12th, 2009 at 1:24pm
You can enable character wrapping by calling setWrapAtCharacter on the TextFormat object associated with the node and passing true as an argument. The following code illustrates this:
node.getTextFormat().setWrapAtCharacter(true);
Henry
Re: Text in a Box
Reply #2 - Aug 12th, 2009 at 1:51pm
hi,
i don't want do brake the words, i want to cut the words on this point.
If i don't cut, the ShapeNode draws me nothing, no Text is to see if it larger tha the free space. I must use one word.
I have looked that i can calculate how many chars can i place in my box, but i need the FontRenderContext for this option an i dont have it.
private String trimToPx(String iText, ShapeNode iNode) {
  Rectangle2D bounds =
    bNode.getFont().getStringBounds(iText, <here i need the FontRenderContex>);
  while (iNode.getBounds().width < bounds.getWidth()) {
    iText = iText.substring(1,iText.length()-1);
    bounds =
      bNode.getFont().getStringBounds(iText+"...", <here i need the FontRenderContex>);
  return iText;
greetings
henry
Re: Text in a Box
Reply #3 - Aug 12th, 2009 at 3:35pm
You could use Diagram.measureString to measure the string considering the current transforms applied to the diagram.
You might also try to assign to the node a TextFormat object whose NoWrap attribute is set to true. This should draw the text on one line and clip it if it's too long.
Henry
Re: Text in a Box
Reply #4 - Aug 17th, 2009 at 12:21pm
Diagram.measureString is perfekt!
thx
Henry
