Normal Topic Move a node with attached nodes (Read 1996 times)
Cornel
Aug 13th, 2009 at 1:18pm
Hi all,
I have the following situation:
a node (with HandlesStyle = SquareHandles and transparent background) to which another node is attached.
The attached node is positioned just above the move handle of its parent.
Now I’m not able to move the parent using the handle. This happens for all adjustment handles, not only for move.
The parent can be moved when the other node is in the same position but it is not attached.
Please advice.
Cornel
Re: Move a node with attached nodes
Reply #1 - Aug 13th, 2009 at 4:04pm
Are you using the custom behavior from this post?
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=124991280...
Cornel
Reply #2 - Aug 14th, 2009 at 5:59am
Hi Stoyan,
I am using a custom behavior with the FC version 5.3.1.23528 (so not the one from the post).
I also have some classes that inherit from ShapeNode, TableNode.
Yesterday I run the demo (grouping example) and I found that the problem does not happen there.
Cornel
Cornel
Reply #3 - Aug 14th, 2009 at 6:36am
Hi Stoyo,
I found the trouble Roll Eyes.
The class of the parent node overrode the HitTestHandle function Embarrassed.
I removed that and now it works like charm.
Thanks for your help.
Cornel
