Normal Topic Demo version problem (Read 6806 times)
x-fgi
Aug 14th, 2009 at 2:08pm
I'doing an evaluation of your product and I find it very intresting....well, let's say... it's wonderful!
I use the Activex version under delphi without problem.
Now I try to test it under Java ( I work on Websphere 6.0)
I created the test example AnchorsFrame but when I run it it crash...
it seems it has a version problem.
any suggestion?
here is the stack strace:
Exception in thread "main" java.lang.UnsupportedClassVersionError: com/mindfusion/diagramming/DiagramView (Unsupported major.minor version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:808 )
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:147)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:475)
at java.net.URLClassLoader.access$500(URLClassLoader.java:109)
at java.net.URLClassLoader$ClassFinder.run(URLClassLoader.java:848 )
at java.security.AccessController.doPrivileged1(Native Method)
at java.security.AccessController.doPrivileged(AccessController.java:389)
at java.net.URLClassLoader.findClass(URLClassLoader.java:371)
at java.lang.ClassLoader.loadClass(ClassLoader.java:570)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:442)
at java.lang.ClassLoader.loadClass(ClassLoader.java:502)
at App.main(App.java:11)
Franco
Re: Demo version problem
Reply #1 - Aug 14th, 2009 at 3:06pm
Thanks 8) What JRE version are you using? The control requires at least Java 1.5.
x-fgi
Reply #2 - Aug 14th, 2009 at 4:33pm
thank you for replying the 14.august Wink
the lastest version I can use n my system is
JRE System Library [WebSphere v6 JRE]
I try to run the updater tools ad it returns to me this as the lastest version available....
Franco
Reply #3 - Aug 14th, 2009 at 6:12pm
Do you know if there is a trial version of this websphere thing? I've found this page but am not sure if any of these download is what you are using:
http://www.ibm.com/developerworks/websphere/downloads/
x-fgi
Reply #4 - Aug 17th, 2009 at 7:43am
Thank you for you reply.
I found the Trials & demos page in the IBM web page
http://www14.software.ibm.com/webapp/download/search.jsp?pn=Rational+Application...
Websphere RSD is based on Eclipse with several IBM propretary Plug-in.
when you told me about version 1.5, what part of Java you was talking about?
i.e. the "About Rational..." contain the information about all installed plug-ins and other things installed....maybe the information we need is there...yes, but what of those thousands!!??  Undecided
thankssss
Franco
Franco
Reply #5 - Aug 17th, 2009 at 9:20am
Which of the six downloads there is the product you are using? By 1.5 I meant  the Java Runtime Environment / virtual machine version. The control should work with JRE versions 1.5 and 1.6 (I think Sun also call them Java 5 and Java 6).
x-fgi
Reply #6 - Aug 17th, 2009 at 10:24am
Java virtual machine report me this:
version 6 update 15 ( buil 1.6.0_15-b03)
about websphere.... the download seems to be the number 1.
but I see now that is referred to version WS7.5
I actually have WS6 installed....and it seems there is no more downloadable trial of WS6
ok, may be the JRE that is too old.
Oh goash! I hope I not have  to migrate my application from 6 to 7...  Cry
Franco
Reply #7 - Aug 17th, 2009 at 12:07pm
You might have several JRE versions installed side-by-side on your system, and from what I know Eclipse lets you choose the one to use with your project. Can you check the version in the Project/Properties window under Compiler Options? Our developer will check how the control works with WS7.5 tomorrow.
x-fgi
Reply #8 - Aug 17th, 2009 at 1:12pm
Hello Stoyan,
you're right, I can select what JRE I use for each project...
the good new is I can switch between Eclipse and WebSphere v5 and WebSphere v6 JRE
the bad news is all Javadoc Url refer to
http://java.sun.com/j2se/1.4.2/docs/api Cry
1.4.2 sound too old!
I try now to download from Java.sun the JRE6...
I don' t know if I must download the whole JDK or not... ??? ok I let you know.
Franco
x-fgi
Reply #9 - Aug 17th, 2009 at 1:53pm
Great! GrinGreat! Grin
I've istalled the JRE 6 and now the program works!!!!
many thaks for your support!!!
the only things I 've done is to comment one line in ...
public AnchorsFrame() {
setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
// setLocationByPlatform(true);
this line won't compile..... Undecided
Franco
Franco
