Hot Topic (More than 10 Replies) Disabling Delete Key for flowcharts. (Read 14225 times)
sm323
Aug 18th, 2009 at 1:55am
I need to disable the delete key in box control  in winforms. Could someone provide some info.
SM
Re: Disabling Delete Key for flowcharts.
Reply #1 - Aug 18th, 2009 at 5:50am
Set DiagramView.DelKeyAction = None.
sm323
Reply #2 - Aug 18th, 2009 at 1:56pm
I am trying to do the folowing but I am unable to set the property.
MindFusion.Diagramming.WinForms.Box test = new Box();
           MindFusion.Diagramming.WinForms.FlowChart tt = new MindFusion.Diagramming.WinForms.FlowChart();
Where I have to set the property?
Reply #3 - Aug 18th, 2009 at 4:04pm
DelKeyAction was added to v5.0.2 of the control; seems you are using an older version. You could handle the ArrowDeleting and BoxDeleting validation events to prevent deleting the items.
sm323
Reply #4 - Aug 18th, 2009 at 4:10pm
Is there a sample that I can look at?
sm323
Reply #5 - Aug 18th, 2009 at 4:12pm
I am using v2.0.50727.
We have inherited box control and created a node and now we want to disable the delete key action.
Are there events I can use to disable the action?
SM
Reply #6 - Aug 18th, 2009 at 4:16pm
There should be BoxDeleting and ArrowDeleting validation events raised when the user presses Del.
sm323
Reply #7 - Aug 18th, 2009 at 4:22pm
Are there any properties I have to set on those events? or I have to cancel the event?
Reply #8 - Aug 18th, 2009 at 5:11pm
If I remember correctly, in older versions you would have to set e.Allow = false. Later we started using the standard .NET validation scheme where you set e.Cancel = true to prevent the operation. I think v2.0.50727 that you mention is the .NET runtime version, and not the Flowchart.NETs' one, so I'm not sure what you should use.
sm323
Reply #9 - Aug 18th, 2009 at 5:42pm
I am not having e.allow or e.cancel property.
Reply #10 - Aug 19th, 2009 at 6:01am
Seems it was called e.Confirm; set it to false to prevent deleting the items.
sm323
Reply #11 - Aug 19th, 2009 at 1:30pm
I am trying using the following way
private void FlowChart_BoxDeleting(object inSender, BoxEventArgs inEvent)
           return;
I couldn't see any of the options that you are telling me to try.
SM
Reply #12 - Aug 19th, 2009 at 3:10pm
Set inEvent.Confirm = false.
sm323
Reply #13 - Aug 19th, 2009 at 3:15pm
There is no confirm option.
sm323
Reply #14 - Aug 20th, 2009 at 5:04pm
I was using wrong eventargs.
I changed to the following
private void FlowChart_BoxDeleting(object inSender, BoxConfirmArgs inEvent)
           inEvent.Confirm = false;
SM
