Normal Topic Scroll linktables. (Read 3110 times)
Mrini
Scroll linktables.
Aug 18th, 2009 at 1:51pm
   I used two link-tables for showing the mapping between certain contents.
I want to display the normal scroll-bars to both tables and also need synchronization in scrolling between the tables so that if one table scroll, other should also get automatically scroll.
Thanks in advance.
Re: Scroll linktables.
Reply #1 - Aug 18th, 2009 at 4:11pm
That's not possible with the current version. For the next release we could add a TableScrolled event to let you synchronize the tables.
There's no built-in support for using standard Swing scrollbars. You might try showing a scrollbar in response to tableSelected and handling the scrollbar events by calling the TableNode.setCurrentRow method. If you manage do that, you might as well call setCurrentRow on both tables to synchronize them.
Mrini
Reply #2 - Aug 19th, 2009 at 7:09am
Hi Stoyo,
Thanks for the reply.
Its working perfect on mouseWheelMoved event Smiley.
Is there any way to show scroll bars for link-tables?
Reply #3 - Aug 19th, 2009 at 11:57am
There is no built-in support for scrollbars. You might try adding your own scrollbars to the pane returned by JFrame.getGlassPane(), at the right-side positions of tables. Any controls you add to the glass-pane should appear over the diagram view. E.g. you could add scrollbars in response to the nodeSelected event and remove them from the deselected handler.
Mrini
Reply #4 - Aug 19th, 2009 at 12:47pm
Sorry to trouble you but Can you please provide me the code hints for that.
Reply #5 - Aug 20th, 2009 at 8:47am
I'm afraid I can't, but our developer will add built-in scrollbars in a couple of weeks.
Mrini
Reply #6 - Aug 20th, 2009 at 9:20am
Ok thanks.  Smiley
