Normal Topic Custom Draw actions (Read 2723 times)
Dexter
Custom Draw actions
Aug 21st, 2009 at 8:34am
Hi there.
I want to customize the drawing of a table node cell. I have overwrite the draw method of the table node and draw the string as I want. But when I look at the diagram the text is not visible. Does any one know what to do?
Cry HELP
Re: Custom Draw actions
Reply #1 - Aug 21st, 2009 at 9:53am
You could set CellCustomDraw = Additional, set the tables' TextColor = Transparent to stop the standard text rendering, and draw the cell text in the DrawCell event handler:
private void diagram_DrawCell(object sender, DrawCellEventArgs e)
	IGraphics g = e.Graphics;
	TableNode.Cell cell = e.Cell;
	RectangleF r = e.Bounds;
	PointF pivot = new PointF(r.X + r.Width / 2, r.Y + r.Height / 2);
	// draw rotated text
	Matrix savedTransform = g.Transform;
	g.TranslateTransform(pivot.X, pivot.Y);
	g.RotateTransform(20);
	g.TranslateTransform(-pivot.X, -pivot.Y);
	StringFormat format = new StringFormat();
	format.Alignment = StringAlignment.Center;
	format.LineAlignment = StringAlignment.Center;
	g.DrawString(cell.Text,
		cell.Font ?? e.Table.Font, Brushes.Black, r, format);
	g.Transform = savedTransform;
