Normal Topic Disable ToolTip in Shapenode (Read 2271 times)
Anshul
Senior Member
Aug 26th, 2009 at 6:17am
Hi Stoyan,
I want to disable ToolTip from ShapeNode at runtime. How is it possible ?
Anshul
Re: Disable ToolTip in Shapenode
Reply #1 - Aug 26th, 2009 at 12:14pm
You want to use the Tooltip property for storing text without showing the tooltips?
Anshul
Senior Member
Reply #2 - Aug 26th, 2009 at 12:27pm
Actually I want to show ToolTip from application startup but for a perticular operation over the node, I want to disable ToolTip i.e. ToolTip text is there but it should not display during that perticular operation over the node.
* looking for ToolTipBehavior.ToolTipEnabledProperty kind of property. Is it possible with ShapeNode.
Anshul
Reply #3 - Aug 26th, 2009 at 12:47pm
The Tooltip property is just a wrapper for the attached ToolTipService.ToolTipProperty. You could try setting ToolTipService.IsEnabled for individual diagram items.
Anshul
Senior Member
Reply #4 - Aug 27th, 2009 at 7:11am
Thanks Stoyan.
