Normal Topic Obtaining text bounds (Read 1164 times)
Dexter
Aug 26th, 2009 at 7:54am
Hi there! Is there any way of calculating if the user double clicks the text of a shape node/table node cell and not the node it self? Meaning the user double click the text and the user double click the region inside the node but not on the text.
Best regards,
dexter
Re: Obtaining text bounds
Reply #1 - Aug 26th, 2009 at 11:58am
You could call the Diagram.MeasureString method to get the text size. Then you can determine the text bounds from the size, the text alignment specified in TextFormat, and from node.Bounds.
