Normal Topic java script :how to set node text font (Read 5285 times)
123danian
Aug 27th, 2009 at 6:56am
some code listed here:
IN javascript
<script>
function NodeCreated(sender,e)
shapenode.setfont(....)
</script>
Here is some problem:i don't know how to create a font object in JavaScript,and by what class,and what namespace to invoke  in"setfont(........)";
All there are not very like in .cs file ????
Re: java script :how to set node text font
Reply #1 - Aug 27th, 2009 at 7:14am
Are you using our ASP.NET diagramming control?
123danian
Reply #2 - Aug 27th, 2009 at 8:42am
ye.....ASP.NET 3.5  Wish my sincere thanks to you for the fuzzy trouble shoot!?
waiting for your answer
Reply #3 - Aug 27th, 2009 at 8:54am
You could call the applet.getScriptHelper().createFont(name, size) method. The applet instance can be accessed like this:
var applet = <%= diagView.AppletElement %>;
123danian
Reply #4 - Aug 28th, 2009 at 12:48am
ye,it works,,thanks very much!!
