Normal Topic setBrush (Read 1857 times)
cpmjones
setBrush
Sep 2nd, 2009 at 12:51pm
While creating Shape Nodes I can define colors and then using two colors, creating a GradientBrush and then set the fill color of the shapeNode using setBrush.
However, if I then want to change the colors and creating a new GradientBrush and using setBrush to change the node's fill color, the shapeNode's fill color does not change.
Is there something I am missing?
Chris
Re: setBrush
Reply #1 - Sep 2nd, 2009 at 2:41pm
Hi Chris,
Could you copy here the code you are using to change the brush?
cpmjones
Re: setBrush
Reply #2 - Sep 2nd, 2009 at 3:12pm
Hi Stoyan,
I just realised my mistake. I generate an image from which the initial colors are set. The shape is displaying the image, hence changing the colors don't change it!
Roll Eyes
Thanks anyway,
Chris
