Normal Topic Question about AllignToGrid (Read 1126 times)
chris
Sep 2nd, 2009 at 3:40pm
Hi Stoyan,
I  have two questions about AllignToGrid property for Diagram control.
1. If there are some nodes and links before the AllignToGrid property is set to true, is there a way to refresh the Diagram to adjust all the elements allign to grid?
2. Can I change the grid spacing?
Thanks a lot!
Re: Question about AllignToGrid
Reply #1 - Sep 2nd, 2009 at 5:05pm
Hi Chris,
1. You could loop over the nodes, call diagram.AlignPointToGrid(node.Bounds.Location) to get the grid point nearest to the node's top-left corner, and then call node.Move to move the node to the aligned point.
2. Set the GridSizeX and GridSizeY properties.
