Normal Topic GetHeaderFromPoint not always working (Read 2572 times)
David Long
Sep 7th, 2009 at 9:45am
In a Lane diagram I am using the following code to detect a double-click on a row header:
       private void diagramView_MouseDoubleClick(object sender, MouseEventArgs e)
           PointF p = diagramView.ClientToDoc(e.Location);
           if (e.Button == MouseButtons.Left)
               Grid grid = flowChart.LaneGrid;
               RectangleF rect = new RectangleF();
               Header header = grid.GetHeaderFromPoint(p, ref rect);
               if (header != null)
This works fine UNLESS the lane diagram has been scrolled horizontally (the row headers are fixed and don't scroll) - in this case header is returned as null.  Is this a bug?
I am using Version 5.3.1
Thanks for your help
DavidL
Re: GetHeaderFromPoint not always working
Reply #1 - Sep 7th, 2009 at 2:34pm
In case of hooked headers, you should use the other GetHeaderFromPoint overload and specify the vertical and horizontal scrolling position of the diagram view. The following code illustrates this:
Header header = grid.GetHeaderFromPoint(p, ref rect,
      new PointF(diagramView.ScrollX, diagramView.ScrollY));
I hope this helps,
David Long
Reply #2 - Sep 8th, 2009 at 10:17am
Many thanks - that works fine.
DavidL
