Normal Topic Header and title (Read 1379 times)
princji
Header and title
Sep 9th, 2009 at 2:58pm
Using NetDiagram, is it possible to add a header and a title to a diagram so that it's always centered at the top of the diagram?
Thanks.
Re: Header and title
Reply #1 - Sep 10th, 2009 at 6:05am
You could add a Transparent shapenode to display the title, and set it Locked so that user cannot select it. Another option is to handle the DrawBackground event: in JavaApplet mode you could assign a JavaScript function to DrawBackgroundScript, and draw the header and title from there using the Java Graphics2D API.
