Normal Topic java.lang.reflect.InvocationTargetException (Read 2249 times)
choohj70
Sep 10th, 2009 at 3:53am
When I try to export to PDF a large network, I am getting java.lang.reflect.InvocationTargetException error.
Can you please confirm that you are getting this error as well?
Thank you
Re: java.lang.reflect.InvocationTargetException
Reply #1 - Sep 10th, 2009 at 6:08am
Could you email us the full exception stack trace, your export code both on the client and server, and the diagram with which it happened?
