Normal Topic Iconnode export to visio? (Read 1458 times)
shu
Sep 11th, 2009 at 8:10am
Hi
It's possible to export IconNodes to Visio? What have I to do for that?
Tanks and kind regards
Re: Iconnode export to visio?
Reply #1 - Sep 11th, 2009 at 12:53pm
VisioExporter does not support custom node types. You could create a copy of the diagram where each IconNode is replaced with two ShapeNodes to display the image and label, and export the copy to Visio. You could also call labelNode.AttachTo(imageNode), and the exporter will create a Visio group from the two nodes.
