Normal Topic Bug on arrange Tree TreeLayoutType (Read 2510 times)
goodiesqq
Sep 12th, 2009 at 2:51pm
For example,
ShapeNode Level 1-3(department level), set to AnchorPattern.TopInBottomOut
ShapeNode Level 4-6(jobTitle level), set to AnchorPattern.LeftInRightOut
Then TreeLayout layout = new TreeLayout();
when layout.Arrange(diagram), all nodes were arranged to TopInBottomOut.
Re: Bug on arrange Tree TreeLayoutType
Reply #1 - Sep 13th, 2009 at 11:32am
TreeLayout ignores anchor points by default. You could set TreeLayout.Anchoring to Keep or Reassign to connect the links to some anchor points. However that won't change the direction of the tree branches, in case that's what you expect.
