Normal Topic Resizing of Diagram (Read 1371 times)
lutz
Resizing of Diagram
Sep 14th, 2009 at 7:47am
i am using a grid with several row headers, but only one column header.
How can i solve the problem, that after enlargement of the column header height the whole diagram is moved downwards but the size displayed isn't changing - bottom region is cut off?
I had set the parameter for enlargement in all directions, but that didn't help.
Thanks in advance
Lutz
Re: Resizing of Diagram
Reply #1 - Sep 14th, 2009 at 10:31am
The Diagram.AutoResize property does not take into consideration the lane grid when determining whether to enlarge the diagram. You have to manually modify the bounding rectangle in response to a change in the lane grid size. The following code illustrates how:
Rect rowHeader = diagram1.LaneGrid.GetRowHeaderBounds();
Rect columnHeader = diagram1.LaneGrid.GetColumnHeaderBounds();
Rect union = Rect.Union(rowHeader, columnHeader);
Rect diagramBounds = diagram1.Bounds;
if (diagramBounds.Right < union.Right)
      diagramBounds.Width = union.Right - diagramBounds.Left;
if (diagramBounds.Bottom < union.Bottom)
      diagramBounds.Height = union.Bottom - diagramBounds.Top;
diagram1.Bounds = diagramBounds;
The variable diagram1 references the Diagram instance.
Use the code above when the size of the column header changes.
