Normal Topic Expander button visibility issue (Read 2552 times)
Anshul
Senior Member
Sep 16th, 2009 at 1:51pm
In our application, we want to display expander button on node only when mouse is over the node. As mouse enters to the node, expander button should be visible and on mouse leaves from that node expander button should be invisible.
We have used Diagram_MouseMove event for this. It is working fine except in one case.
If we move mouse rapidly over the nodes, some expander button remains on the node while mouse is not over them.
We have prepared a sample for the same and sending it to your support ID, please have a look at it.
To re-produce the issue:
Move mouse rapidly over the node from top to bottom and bottom to top.
Anshul
Re: Expander button visibility issue
Reply #1 - Sep 16th, 2009 at 3:48pm
You could keep a reference to the node that currently displays an expander, and always hide its expander before showing one for a new node.
Anshul
Senior Member
Reply #2 - Sep 17th, 2009 at 6:35am
Hi Stoyan,
Thanks for the reply.
As you have suggested, we have already kept a refrence of that node in the sample but still we are getting this issue.
Please have a look at the sample and suggest something.
Anshul
Reply #3 - Sep 17th, 2009 at 1:18pm
However you should hide the expand button of the previous node before setting the reference to point to the new node. So it should work fine if you swap the two if statements in the MouseMove handler:
void diagram_MouseMove(object sender, MouseEventArgs e)
	Point mousePosition = e.GetPosition(diagram.DocumentPlane);
	DiagramItem item = diagram.GetItemAt(mousePosition, true);
	if (expandVisibleNode != null && !expandVisibleNode.Bounds.Contains(mousePosition))
		ShapeNode expandNode = expandVisibleNode.SubordinateGroup.AttachedNodes[0] as ShapeNode;
		expandNode.Visible = false;
	if (item != null)
		ShapeNode node = item as ShapeNode;
		if (node != null && node.SubordinateGroup != null)
			ShapeNode expandNode = node.SubordinateGroup.AttachedNodes[0] as ShapeNode;
			expandNode.Visible = true;
			expandVisibleNode = node;
Anshul
Senior Member
Reply #4 - Sep 17th, 2009 at 4:07pm
Thanks a lot stoyan Smiley
