Normal Topic can't delete boxes attached to table (Read 1772 times)
chuckdawit
Sep 16th, 2009 at 7:01pm
I have a table with two attached boxes and when I click table on the form to delete it, the table deletes but not the two boxes attached to it. Can anyone help? I will paste the code that creates the table and two boxes and the event that gets called when the delete is pressed
MindFusion.FlowChartX.Table textBox = new MindFusion.FlowChartX.Table(strategyFlowChart);
textBox.EnableStyledText = true;
textBox.Selected = false;
Graphics graphics = Graphics.FromHwnd(this.Handle);
graphics.PageUnit = GraphicsUnit.Millimeter;
textBox.RowHeight = _smallFont.GetHeight(graphics) + 2;
textBox.Font = _smallFont;
RectangleF rect = textBox.BoundingRect;
rect.X = addPairsMouseDownPoint.X;
rect.Y = addPairsMouseDownPoint.Y;
rect.Width = 50;
textBox.SetRect(rect, false);
float offset = 70;
strategyFlowChart.Add(textBox);
textBox.Move(rect.X + offset, rect.Y + offset);
StrategyChanged(this, EventArgs.Empty);
SymbolAdded();
textBox.FillColor = Color.Moccasin;
MindFusion.FlowChartX.Box textBox1 = strategyFlowChart.CreateBox(rect.X + 4 + offset, rect.Y + 20 + offset, 10, 10);
//MindFusion.FlowChartX.Table textBox1 = strategyFlowChart.CreateTable(rect.X + 4 + offset, rect.Y + 20 + offset, 10, 10);
textBox1.PolyTextLayout = true;
textBox1.EnableStyledText = true;
textBox1.Text = "P1-A";
textBox1.Selected = false;
textBox1.AttachTo(textBox, MindFusion.FlowChartX.AttachToNode.BottomLeft);
textBox1.Locked = true;
textBox1.Style = MindFusion.FlowChartX.BoxStyle.Shape;
textBox1.Shape = MindFusion.FlowChartX.ShapeTemplate.OffpageReference;
strategyFlowChart.Add(textBox1);
textBox1.FillColor = Color.Moccasin;
MindFusion.FlowChartX.Box textBox2 = strategyFlowChart.CreateBox(rect.X + 36 + offset, rect.Y + 20 + offset, 10, 10);
textBox2.PolyTextLayout = true;
textBox2.EnableStyledText = true;
textBox2.Text = "P1-B";
textBox2.Selected = false;
textBox2.AttachTo(textBox, MindFusion.FlowChartX.AttachToNode.BottomRight);
textBox2.Locked = true;
textBox2.Style = MindFusion.FlowChartX.BoxStyle.Shape;
textBox2.Shape = MindFusion.FlowChartX.ShapeTemplate.OffpageReference;
strategyFlowChart.Add(textBox2);
textBox2.FillColor = Color.Moccasin;
private void strategyFlowChart_TableDeleted(object sender, MindFusion.FlowChartX.TableEventArgs e)
{ //delete table stuff
Re: can't delete boxes attached to table
Reply #1 - Sep 16th, 2009 at 7:15pm
After attaching the boxes, set table.SubordinateGroup.AutoDeleteItems = true.
chuckdawit
Reply #2 - Sep 16th, 2009 at 7:32pm
yes that works! thanks!
