Hot Topic (More than 10 Replies) custom propeties (Read 10457 times)
Re: custom propeties
Reply #15 - Oct 2nd, 2009 at 9:31am
Change the server-side SerializeTag handler to this:
void diagram_SerializeTag(object sender, SerializeTagEventArgs e)
	Dictionary<string, string> table = (Dictionary<string, string>)e.Tag;
	string[] serialized = new string[table.Count * 2];
	int c = 0;
	foreach (KeyValuePair<string, string> p in table)
		serialized[c++] = p.Key;
		serialized[c++] = p.Value;
	e.Representation.InnerText = String.Join(";", serialized);
	e.Handled = true;
and on the client side add this function as DeserializeTagScript:
function onDeserializeTag(tagString)
	var strings = tagString.split(";");
	var customProps = new Object();
	for (i = 0; i < strings.length; i += 2)
		customProps[strings[i]] = strings[i + 1];
	return customProps;
Reply #16 - Oct 2nd, 2009 at 9:33am
and now if you call node.getTag() on the client side, you will get a JS object whose properties and values can be enumerated like this
for (var property in tag)
	if (tag.hasOwnProperty(property))
		document.write(property + " " + tag[property];
