Normal Topic Center Text on a Diagram link (Read 3888 times)
donalmeida
Yay...
Oct 6th, 2009 at 6:42pm
How do I center the text on a (Diagram link). Right now the text is seen on the far right of the Link and is almost covering the Text of the destination node.
Don Almeida
Don Almeida.
Re: Center Text on a Diagram link
Reply #1 - Oct 7th, 2009 at 6:43am
It looks nicely centered in my test project. Are you using version 1.1? The text should be centered over the middle segment of the link if it has an odd number of segments, or otherwise centered over the middle control point if there are an even number of segments.
donalmeida
Yay...
Reply #2 - Oct 7th, 2009 at 3:36pm
I might have to admit I am new to these controls, so I am not aware of the term segments.
this is how I create a link:
DiagramLink link = new DiagramLink(diagram, fromNode, toNode)
Pen = new Pen(Brushes.Black),
Style = LinkStyle.Bezier,
Text = "Some Text",
diagram.Links.Add(link);
Do I need to set some other property to center the Text on the Link?
Don Almeida.
Reply #3 - Oct 8th, 2009 at 7:31am
Ok, centering does not work for Bezier links indeed. We are releasing a new version in a few days and will fix this there.
donalmeida
Yay...
Reply #4 - Oct 8th, 2009 at 3:33pm
Thank you for fixing this....you guys are Awesome...
Don Almeida.
Reply #5 - Oct 9th, 2009 at 7:48am
Try this version:
https://mindfusion.eu/_beta/diaglite12_linkstyle.zip
The problem was that the link.Style setter added two new control points at the end of the link, and this the text was centered relatively to them. Now the new points are added at 1/3 and 2/3 of the link length and the text should appear centered correctly.
Piraet
Reply #6 - Nov 17th, 2009 at 2:31pm
Is this also available for the ASP.NET version? It seems like I'm having the same problem. (text is over the arrow head, instead of center of link)
Reply #7 - Nov 17th, 2009 at 6:07pm
It's not available in the ASP.NET version yet. You might rebuild the ClientApp project with a reference to the Diagramlite V1.2 assembly to get a fixed .xap file.
