Hot Topic (More than 10 Replies) Scroll link tables slow down the performance. (Read 9423 times)
Re: Scroll link tables slow down the performance.
Reply #15 - Mar 25th, 2010 at 10:33am
Perhaps you could use the diagram.measureString method for this, or the FontMetrics class from the Java Graphics2D API which you would call indirectlly through measureString?
Mrini
Reply #16 - Mar 26th, 2010 at 8:04am
But how can I use diagram.measureString as the diagram area is divided between the 2 linktables and mapping links.
I tried but its not working.
Reply #17 - Mar 26th, 2010 at 9:39am
How were you using ShapeNodes and JTextAreas? If you need to measure the height for a fixed width, I suppose you will have to loop over the string characters and measure its substrings until they fit into the width, then advance the height with the returned Dimension2D.height.
