Normal Topic Unable to select node (Read 2531 times)
ayushneema
Oct 7th, 2009 at 3:43pm
I have created a node with following property:
mainNode.HandlesStyle = HandlesStyle.EasyMove;
		    mainNode.EnabledHandles = AdjustmentHandles.Move|AdjustmentHandles.ResizeHandles;
but i am unable to select to node by mouse strech.
Ayush Neema
Re: Unable to select node
Reply #1 - Oct 8th, 2009 at 7:18am
This could happen if its Locked property is enabled, or if you handle NodeSelecting and set e.Cancel; = true.
ayushneema
Reply #2 - Oct 8th, 2009 at 7:40am
Hi stoyan,
I checked both the property. I am capturing  nodeSelection event but I am  not setting the e.cancel= true. I also found that node.locaked is false.
Ayush Neema
Reply #3 - Oct 8th, 2009 at 10:13am
Could you email us a sample project that shows such node?
Anshul
Senior Member
Reply #4 - Oct 16th, 2009 at 11:59am
Hi Stoyan,
Our problem is now solved. Thanks Smiley
