Normal Topic DiagramNodeCollection (Read 1398 times)
mberger
Oct 10th, 2009 at 8:42am
Im using some DiagramNodeCollections in my Application. Is it possible to firing an event if a node are added or deleted to this collections?
greeze Marco
Re: DiagramNodeCollection
Reply #1 - Oct 10th, 2009 at 5:35pm
Hi Marco,
There's an internal constructor that can be used to make the collection raise events, so you could use it if you have the source code. Otherwise we'll make it public for the next release.
Reply #2 - Oct 11th, 2009 at 9:15am
Actually you can use for this purpose the ObservableCollection generic class from the System.Collections.ObjectModel namespace. Create an ObservableCollection<DiagramNode> instance and handle its CollectionChanged event. The Action event argument specifies whether an item is added to or removed from the collection.
