Normal Topic Highlight anchor on mouse over (Read 1763 times)
oOAnriOo
Oct 12th, 2009 at 11:35am
I have a bunch of custom drawn anchors i need to highlight when the mouse hovers over them.
Unfortunately there is no mouseover event on anchors and the Diagram.GetItemAt() does not trigger on anchors.
Is there any other way I can accomplish this?
Re: Highlight anchor on mouse over
Reply #1 - Oct 12th, 2009 at 12:38pm
Try using the GetNodeAt overload that takes a threshold argument, and then the GetAnchorAt method from this post -
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=125049956...
You must use the RectangleF and PointF types instead of the WPF's Rect & Point method shown in the post above.
oOAnriOo
Reply #2 - Oct 12th, 2009 at 1:12pm
Perfect!!  That would work..
Any idea how to force a redraw of the anchor/node?
(I'm testing the component, so it might be quite basic questions I have)
Reply #3 - Oct 12th, 2009 at 2:19pm
Try with diagram.Invalidate(node.getRepaintRect()).
