Hot Topic (More than 10 Replies) Re: Binding Uniqueid to Shapenode of Shaplist (Read 8070 times)
kumarsrmt
Reply #15 - Oct 13th, 2009 at 3:12pm
Thanks for you prompt response
here when a node creted it will call a page crete.asp.which will allow to insert location ,status and unique id. in database table called xyxy.when we clicksave butoon in crete.asp our main page will refreshed( i did some jaascript forthis in creta.asp page)
after that i am getting the values from XyXy on node by using sql query
at this this time i am unable to bind data..
anybody didi this before ..any exampleor sample code will be appriciated
Reply #16 - Oct 13th, 2009 at 3:30pm
Try adding to your main page an onclose handler for the window that shows create.aspx, and call the form.submit() method from the handler.
