Hot Topic (More than 10 Replies) Unique type (Read 5451 times)
learner123
Unique type
Oct 13th, 2009 at 6:03pm
Hi
i am using flow charter sample project
here i am i am using only 3 shapes
start
terminate
and decision
i am getting uniqued id for each node in onnodecretaed event
i want to drag 5 number of decision nodes..is it possible to get uniquetype for each decision shape..that means when i drag a decision node i want to get uniquetype xxx1 and for second node i want to get xxx1 for third i want to get decisionxxx3..
for start we are uing like this
start.Shape=Shapes.Start
start.text= start
how can we assign values for these
xxx1 and xxx2 and xxx3
can you send some exapmlls
cna you please send some sample code
« Last Edit: Oct 14th, 2009 at 4:33am by learner123 »
Re: Unique type
Reply #1 - Oct 14th, 2009 at 7:18am
try using this function:
function getNumNodes(shapeId, diagram)
	var c = 0;
	for (i = 0; i < diagram.getNodes().size(); ++i)
		if (diagram.getNodes().get(i).getShape().getId() == shapeId)
			c++;
	return c;
It assumes all nodes are of the ShapeNode type.
learner123
Re: Unique type
Reply #2 - Oct 14th, 2009 at 10:32am
In which event i have to call this function and can explain what it returns
Re: Unique type
Reply #3 - Oct 14th, 2009 at 11:06am
It returns the number of nodes with the specified shape id. You could call it from the NodeCreatedScript, passing args.getNode().getShape().getId() as the first argument and applet.getDiagram() as the second argument.
learner123
Re: Unique type
Reply #4 - Oct 14th, 2009 at 1:11pm
HI
tried like this
function onNodeCreated(sender, args)
args.getNode().getShape().getId(getNumNodes());;
applet.getDiagram(getNumNodes()) ;
var c = 0;
c++;
document.getElementById("tbid").value=c;
but its not return anything..i am not getting any value
Re: Unique type
Reply #5 - Oct 14th, 2009 at 1:37pm
You have a lot to learn indeed. The things between the parentheses in the function declaration are parameters and you should pass respectively the shape id and the diagram instance as arguments when calling the function. E.g. if the control's ID is diagramView, and assuming you keep the "return c;" statement in the function:
var diagram = <%=diagramView.AppletElement%>.getDiagram();
var shapeId = args.getNode().getShape().getId();
var numNodes = getNumNodes(shapeId, diagram);
Now you can concatenate shapeId + numNodes to get something like "Decision3".
learner123
Re: Unique type
Reply #6 - Oct 14th, 2009 at 2:33pm
excellent it is working for me
var Nodename=shapeId + numNodes;
here i am getting nodename ..but 1 asked you before
start.text= "start "
how we can assign values or bind values for
Nodename
please send me any code if you have
thanks for your time
Re: Unique type
Reply #7 - Oct 14th, 2009 at 5:09pm
There is no built-in databinding. You should run a select query, loop over the dataset rows and copy the field values to their corresponding node properties.
learner123
Re: Unique type
Reply #8 - Oct 14th, 2009 at 5:14pm
any example or sample code will help me
thanks
learner123
Re: Unique type
Reply #9 - Oct 14th, 2009 at 5:17pm
here i am getting nodename ..iam saving it in to database .
Now iam retrieving the nodename by this code
string nodename= ds.Tables["data"].Rows[i]["nodename"].ToString();.
string nodetext= ds.Tables["data"].Rows[i]["nodetext"].ToString();.
So how can i bind the nodenames to shapes.
like
Start.Shape=Shapes.Decision
Start.Text="Start"
Here Decision i have to bind dynamically means I want like this
Start.Shape=Shapes.nodename
Start.text=nodetext
Re: Unique type
Reply #10 - Oct 15th, 2009 at 9:20am
If you want to use this Nodename as an id, assign it to the Tag property and later use the FindNode method to get the DiagramNode. This example shows that, using your previous date/time based IDs:
https://mindfusion.eu/_samples/netdiag_SqlServerStore.zip
