Normal Topic advice for Splitting the flowchart diagram (Read 1520 times)
mrreddy82
Oct 15th, 2009 at 11:34am
Hi Stoyan ,
How can provide the diagram to the users so that users can make their
1)
Own group of nodes
2)
Making own color for any node by clicking the mouse or some other event
3)
If possible while printing also they should be able to print some group of nodes
Please give me some advice
Thanks!!!!!!!!!!
Re: advice for Splitting the flowchart diagram
Reply #1 - Oct 15th, 2009 at 2:48pm
Hi there,
1. You might loop over diagram.Selection.Nodes and call node.AtatchTo(diagram.ActiveItem).
2. node.Brush = new MindFusion.Drawing.SolidBrush(someColor);
3. Try setting Printable = false for the items that are not in that group.
mrreddy82
Reply #2 - Oct 16th, 2009 at 1:02pm
Hi Stoyan ,
Thanks for your explanation
For question 1 and 2 I understood it
For question 3 could you please explain me about printable in detail
Thanks a lot!!!!!!!!!
Reply #3 - Oct 16th, 2009 at 3:59pm
If what you need is to print just the selected items, loop over diagram.Items and set item.Printable = item.Selected. Then the Print method should skip items that are not printable/selected.
