Normal Topic Require diagram_PreviewClicked (Read 1700 times)
Anshul
Senior Member
Oct 20th, 2009 at 3:54pm
Hi Stoyan,
We want some digram_PreviewClicked event for our application because we want to perform some operation before click event of the diagram. We don’t want to use mouseDown because it also works while click on the node. Is there any event to handle such kind of scenario?
Please suggest?
Anshul
Some additional information:
We want to drag mouse on the diagram to select the node while focus is not in the diagram. In this case while we start drag, we are not getting clicked event of the diagram. We don't want to use MouseDown for the same as it is giving some overhead in our application so we want somethinf PreviewClicked or any other event to perform the operation.
Please suggest?
« Last Edit: Oct 21st, 2009 at 6:28am by Anshul »
Anshul
Senior Member
Re: Require diagram_PreviewClicked
Reply #1 - Oct 22nd, 2009 at 7:27am
Hi Stoyan,
Any update for this?
Anshul
Reply #2 - Oct 23rd, 2009 at 8:22am
The Diagram.Clicked event is raised when clicking outside any nodes/links, but only after you release the mouse button. You will have to use MouseDown or PreviewMouseDown and check if there's a node under the mouse pointer.
