Normal Topic Custom DiagramView ScrollBars (Read 969 times)
antonis74
Oct 20th, 2009 at 7:21pm
I need to change the DiagramView Scrollbars color.
In a similar post someone suggested to use the HScrollbar and VScrollbar properties but the problem is that these properties Default Back and Fore Color are readonly.
Is there any other solution?
Thanks in advance
Re: Custom DiagramView ScrollBars
Reply #1 - Oct 21st, 2009 at 7:45am
The .NET scrollbars do not allow that. You will have to use custom scrollbar controls. For example, check this thread:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_feat;action=display;num=125083644...
