Normal Topic LoadFromString method (Read 1267 times)
123danian
Oct 22nd, 2009 at 7:50am
hi, when i use the LoadFromString method,i found it cannot get the nodes' images, and some other attributes.
for example: there is a ShapeNode in the diagram
node.image = ...
node.transparent = true;
firstly, i use the SaveToString method to save the diagram , then i use  LoadFromString to load the diagram, the node's image missed,and the transparent attribute also worng, so how can i do to avoid the porblem?
thanks!
Re: LoadFromString method
Reply #1 - Oct 22nd, 2009 at 11:46am
There aren't image encoders provided by Silverlight, so the image data is not saved. You could associate an image to a node using an URI, and then it should be saved and restored successfully through the URI. E.g. you can specify an image URL on your site via the ImageWebLocation property, or image location in the XAP file via ImageResourceLocation.
