Normal Topic Hiding the transparent gray selection rectangle (Read 3576 times)
priyanka
Oct 23rd, 2009 at 7:16am
I need to diable the visibilty of the selection rectangle(transparent gray colored) which appears when we want to select a range of node on diagram.
What property need to be set for it..??
Priyanka
Re: Hiding the transparent gray selection rectangl
Reply #1 - Oct 23rd, 2009 at 8:11am
Set the Diagram.Selection.Brush property to SolidColorBrush(Color.Transparent).
priyanka
Reply #2 - Oct 23rd, 2009 at 8:24am
Thanks for yoyr reply.
But this will set the background of the item which is selected.
I want to remove the visibility of the rectangle which appear when we click on any blank area of diagram and drag the mouse to some other location(on diagram such taht it covers some nodes within it) to select multiple nodes.!!!!
This is a TRANSPARENT GRAY SHAPE...!!!
I need to off the visibility of this selection rectangle.
How could i do this..!!??
Reply #3 - Oct 23rd, 2009 at 8:31am
This doesn't change the selected items, only the color of the selection rectangle.
priyanka
Reply #4 - Oct 23rd, 2009 at 9:02am
Hi Stoyo,
It Worked....  Cheesy
priyanka
Reply #5 - Oct 29th, 2009 at 12:55pm
Hi Stoyo,
What if at some point in code I want to change back to the default selection rectangle which used to come before making it transparent.
What need to be set for it.!!!
Priyanka
Reply #6 - Oct 29th, 2009 at 1:43pm
Set it to new SolidColorBrush(Color.FromArgb(75, c.R, c.G, c.B)), where c = SystemColors.HighlightBrush.Color.
priyanka
Reply #7 - Oct 29th, 2009 at 1:57pm
Thanks Stoyo
It worked too.....Cheesy
Priyanka
