Hot Topic (More than 10 Replies) Problem with CopyToClipboard (Read 5517 times)
mberger
Oct 27th, 2009 at 10:50am
hi,
i know that i have to provide a copy constructor in my custom SVGNode class for clipboard operations. How should this copy constructor look like in vb.net?
greeze Marco
Re: Problem with CopyToClipboard
Reply #1 - Oct 27th, 2009 at 11:41am
It should look like this:
Public Sub New(ByVal protoype As MyNode)
	MyBase.New(protoype)
End Sub
mberger
Reply #2 - Oct 27th, 2009 at 12:03pm
Hi Stoyo,
CopyFromClipboard works...
But if i try to PasteFromClipboard, PasteFromClipboard returns false?
greeze Marco
Reply #3 - Oct 27th, 2009 at 1:19pm
Hi Marco,
Have you called the RegisterItemClass method to register the custom class for serialization?
mberger
Reply #4 - Oct 27th, 2009 at 2:54pm
Hi Stoyo,
i got it - but now i have an other problem.
i provide some properties in my customnodes. What i have to do, that this properties will be copied too?
Marco
Reply #5 - Oct 27th, 2009 at 3:36pm
Hi Marco,
Apart from copying them in the copy constructor, you must also implement the binary serialization methods - SaveTo(BinaryWriter) and LoadFrom(BinaryReader).
mberger
Reply #6 - Oct 27th, 2009 at 3:50pm
Ok i have fixed the proiblem with the properties,
... but is it also possible to copy attached Nodes?
I have attached some Nodes to my customnode but if i paste my customnode from the clipboard the attached node will not be copied to the diagram.
Marco
Reply #7 - Oct 28th, 2009 at 7:37am
Set the boolean 'groups' argument of CopyToClipboard to true.
mberger
Reply #8 - Oct 28th, 2009 at 12:43pm
Hi Stoyo,
... thanks a lot for your support !!!
But i have now a last problem with the copy and paste action. I have a custom DiagramLink class with the following copy constructor
    Public Sub New(ByVal prototype As CustomLink, ByVal Origin As DiagramNode, ByVal Destination As DiagramNode)
        MyBase.new(prototype, Origin, Destination)
    End Sub
Now if i try to paste a CustomLink from the clipboard, i get a InvalidCastException
"Unable to cast object of DiagramLink to type CustomLink "
What's wrong with my copy constructor ???
greeze Marco
Reply #9 - Oct 28th, 2009 at 1:38pm
There's nothing wrong, but actually the requirement for clipboard support is to implement the DiagramItem.Clone method, so you should do that, say by returning an instance created with that copy constructor. It seems for nodes this works out-of-the-box because their default Clone implementation calls the copy constructor automatically.
mberger
Reply #10 - Oct 28th, 2009 at 1:57pm
Ok,
i add the following code to my CustomLink class
    Public Overrides Function Clone(ByVal clipboard As Boolean) As MindFusion.Diagramming.DiagramItem
	  Return MyBase.Clone(clipboard)
    End Function
But nothing happends.... ???
greeze Marco
Reply #11 - Oct 28th, 2009 at 3:37pm
base.Clone returns a DiagramLink. You could call your copy constructor instead:
Return New MyLink(Me)
mberger
Reply #12 - Oct 28th, 2009 at 4:03pm
hmmm,
it doesn't work for me...
"Registration of the Custom DiagramItems"
    Public Sub RegisterDiagramItems()
        ' Registrieren der DiagramItems
        Diagram.RegisterItemClass(GetType(SVGNode_Node), "SVGNode", 1)
        Diagram.RegisterItemClass(GetType(SVGNode_Inlet), "SVGInlet", 1)
        Diagram.RegisterItemClass(GetType(SVGNode_Outlet), "SVGOutlet", 1)
        Diagram.RegisterItemClass(GetType(SVGNode_Resistance), "SVGResistance", 1)
        Diagram.RegisterItemClass(GetType(CustomLink), "CustomLink", 1)
    End Sub
"CustomLink Class"
Public Class CustomLink
    Inherits DiagramLink
    Public Sub New(ByVal prototype As CustomLink, ByVal origin As DiagramNode, ByVal destination As DiagramNode)
        MyBase.new(prototype, origin, destination)
        Tag_BrokenLink = prototype.Tag_BrokenLink
        FakeVolumFlow = prototype.FakeVolumFlow
    End Sub
    Public Sub New(ByVal diagram As Diagram, ByVal Origin As DiagramNode, ByVal Destination As DiagramNode)
        MyBase.New(diagram, Origin, Destination)
        Tag = "hasNoAttechedNodes"
        Tag_BrokenLink = ""
        FakeVolumFlow = 0
        ' Look and Feel
        BaseShape = MindFusion.Diagramming.ArrowHead.None
        HeadShape = MindFusion.Diagramming.ArrowHead.Triangle
        Pen.DashStyle = Drawing2D.DashStyle.Solid
        Dim CBrush As New MindFusion.Drawing.SolidBrush(System.Drawing.Color.FromArgb(255, 60, 60, 60))
        Pen.Brush = CBrush
        Brush = CBrush
        HeadPen.Brush = CBrush
        Selected = False
    End Sub
        Return New CustomLink(Me, Me.Origin, Me.Destination)
    End Function
#Region "Save / Load"
    Protected Overrides Sub SaveTo(ByVal writer As System.IO.BinaryWriter, ByVal ctx As PersistContext)
        MyBase.SaveTo(writer, ctx)
        writer.Write(_Tag_BrokenLink)
        writer.Write(_FakeVolumFlow)
    End Sub
    Protected Overrides Sub LoadFrom(ByVal reader As System.IO.BinaryReader, ByVal ctx As PersistContext)
        MyBase.LoadFrom(reader, ctx)
        _Tag_BrokenLink = reader.ReadString
        _FakeVolumFlow = reader.ReadDouble
    End Sub
#End Region
    Public Property Tag_BrokenLink() As String
        Get
            Return _Tag_BrokenLink
        End Get
        Set(ByVal value As String)
            _Tag_BrokenLink = value
        End Set
    End Property
    Public Property FakeVolumFlow() As Double
        Get
            Return _FakeVolumFlow
        End Get
        Set(ByVal value As Double)
            _FakeVolumFlow = value
        End Set
    End Property
    Private _Tag_BrokenLink
    Private _FakeVolumFlow
End Class
Should i implement the DiagramItem.Clone method in all custom nodes or only in the customLink class ?
Reply #13 - Oct 29th, 2009 at 2:45pm
For successful serialization you must add a no-args constructor, or one that takes just a Diagram argument. Otherwise the load method won't be able to create an instance of the custom class. This worked for me:
	Public Sub New(ByVal d As Diagram)
		MyBase.New(d)
	End Sub
	End Sub
	End Function
End Class
mberger
Reply #14 - Oct 30th, 2009 at 11:26am
Hi Stoyo,
... now it works fine!
thanks a lot for your support.  Grin
cheers Marco
