Very Hot Topic (More than 25 Replies) SVG export (Read 16825 times)
Dexter
SVG export
Sep 2nd, 2009 at 12:47pm
I am testing the svg exporter. I export a diagram to svg and it is ugly, very ugly.  Here is how I export the diagram.
SvgExporter exporter = new SvgExporter();
			  exporter.Export(diagram, saveFileDialog.FileName);
And here is what has exit:
http://a.imagehost.org/download/0734/test
Please let me know if I am doing something wrong or not doing something
Best regards
Dexter
Re: SVG export
Reply #1 - Oct 26th, 2009 at 2:43pm
Hi there! does any body knows an answer to this? please is very important stuff....
Dexter
Re: SVG export
Reply #2 - Oct 26th, 2009 at 2:49pm
Are you exporting from the Silverlight version and opening the diagram using the diagramming.dll for ASP.NET?
Dexter
Re: SVG export
Reply #3 - Oct 26th, 2009 at 3:05pm
No. I am using dll's from the win forms distribution
Re: SVG export
Reply #4 - Oct 26th, 2009 at 3:18pm
Could you call debug.print() for the nodes' font sizes and units after loading the diagram? What values can you see printed?
Dexter
Re: SVG export
Reply #5 - Oct 26th, 2009 at 3:32pm
Font size = 2,333333; font units = Millimeter
this is the result after loading all items on the diagram. the svg is the following
http://h.imagehost.org/download/0202/test
Re: SVG export
Reply #6 - Oct 26th, 2009 at 3:39pm
And what is the Diagram.MeasureUnit value?
Dexter
Re: SVG export
Reply #7 - Oct 26th, 2009 at 3:41pm
Millimeter
Re: SVG export
Reply #8 - Oct 26th, 2009 at 4:08pm
It worked fine for me:
http://mindfusion.eu/_samples/svg_233mm.svg
Could you save the diagram to xml and email it to support@mindfusion.eu?
Dexter
Re: SVG export
Reply #9 - Oct 27th, 2009 at 7:58am
I have send the xml file to the support. The subject contains a link to this forum thread and is addressed to you. I am waiting to see if I am doing something wrong there.
Best regards,
Dexter
Re: SVG export
Reply #10 - Oct 27th, 2009 at 11:57am
There are some custom types and custom-drawn tables and cells in that file. Could you copy here any custom-drawing code you are using? The exported SVG looked fine when we replaced the custom nodes with standard ShapeNodes and TableNodes.
Dexter
Re: SVG export
Reply #11 - Oct 27th, 2009 at 12:46pm
The table nod has the following custom draw mechanism:
	  public override void Draw(IGraphics graphics, RenderOptions options)
		Rows[1].Height = Bounds.Height - Rows[0].Height - Pen.Width;
		base.Draw(graphics, options);
public void DrawCell(DrawCellEventArgs e)
		IGraphics g = e.Graphics;
		TableNode.Cell cell = e.Cell;
		StringFormat format = cell.TextFormat;
		RectangleF r = e.Bounds;
		if (e.Cell.Equals(nameCell))
		    float newWidth = CalculateWitdth(e.Cell.Text, Font, r.Width, e.Cell.TextFormat, r.Height);
		    if (newWidth > r.Width)
			  r.X = r.X - (newWidth - r.Width) / 2;
		    r.Width = newWidth;
		    g.DrawString(cell.Text,
			  cell.Font ?? e.Table.Font, Brushes.Black, r, format);
		    return;
		g.DrawString(cell.Text, cell.Font ?? e.Table.Font, Brushes.Black, r, format);
For a shape node the drawing is the following
 public override void Draw(MindFusion.Drawing.IGraphics graphics, RenderOptions options)
		System.Drawing.Pen pen = Pen.CreateGdiPen(Bounds);
		graphics.DrawRectangle(pen, InternalBounds.X, InternalBounds.Y, InternalBounds.Width, InternalBounds.Height);
		pen.Dispose();
		SizeF textSize = graphics.MeasureString(Text, Font, 0, TextFormat);
		textSize.Width += 2;
		RectangleF textOutline = new RectangleF(
						    InternalBounds.X + (InternalBounds.Width - textSize.Width) / 2,
						    InternalBounds.Y - textSize.Height / 2,
						    textSize.Width,
						    textSize.Height);
		System.Drawing.Brush brush = new SolidBrush(Color.White);
		graphics.FillRectangle(brush, textOutline);
		brush.Dispose();
		graphics.DrawString(Text, Font, new SolidBrush(TextColor), textOutline, TextFormat);
	  public override void DrawHandles(MindFusion.Drawing.IGraphics graphics, Color color)
		if (Parent != null)
		    RectangleF rc = Utilities.NormalizeRect(InternalBounds);
		    InternalUtils.DrawSelHandles(graphics, color, Parent.DisabledHandlesColor, rc, RotationAngle, this.EnabledHandles, Parent.ShowDisabledHandles, this.HandlesStyle, Parent.AdjustmentHandlesSize);
A shape node in the xml file has the following shape defined:
public static Shape TransactionKind
		get
		    return new Shape(
		     Shapes.Ellipse.Outline,
		     Shapes.Decision.Outline,
		     null,
		     FillMode.Winding, "TK");
and one custom link has the following draw method
		Pen pen;
		Brush brush;
		if (base.ShouldRender())
		    pen = base.Pen.CreateGdiPen();
		    brush = new SolidBrush(pen.Color);
		    //determine where the diamond should be drawn at the origin or destination
		    //depending from where the user start drawing
		    int diamondPosition = 0;
		    if (!(this.Origin is ActorRoleView))
			  diamondPosition = ControlPoints.Count - 1;
		    PointF e = ControlPoints[diamondPosition];
		    RectangleF bounds = new RectangleF(e.X - diamondSize / 2, e.Y - diamondSize / 2, diamondSize, diamondSize);
		    GraphicsPath path = new GraphicsPath();
		    path.AddRectangle(bounds);
		    Matrix r = new Matrix();
		    r.RotateAt(45, e);
		    path.Transform(r);
		    graphics.FillPath(brush, path);
		    pen.Dispose();
		    brush.Dispose();
		else
		    return;
Re: SVG export
Reply #12 - Oct 27th, 2009 at 4:19pm
I couldn't reproduce it. Could you also post the svg export code? Are you using the latest WinForm version?
Dexter
Re: SVG export
Reply #13 - Oct 28th, 2009 at 6:58am
The dll used in the application has the following attributes:
Runtime Version: v2.0.50727 and Version: 5.3.2.23161 but I am using a trial version of flow chart .net.
The code used to export the diagram is the following:
SvgExporter svgExporter = new SvgExporter();
				svgExporter.ExternalImages = false;
				svgExporter.Export(diagram.DiagramDocument, saveFileDialog.FileName);
there the DiagramDocument is a property that returns the diagram where the painting happens.
Du to the fact that I have custom shapes defined must I set some custom draw properties for the shapes concerned? Because now I have only the CellCustomDraw set to Aditional.
Re: SVG export
Reply #14 - Oct 28th, 2009 at 8:42am
Should we test all this in a Windows Forms application? You have posted in the Silverlight forum so I assumed you are sending the diagram to an ASP.NET page and exporting from there. Could you send us a test app or site that contains your custom classes (at least the drawing code), and have all diagram / diagramview properties from your main project?
