Normal Topic Copy to clipboard issues (Read 2536 times)
hrumayor
Oct 28th, 2009 at 5:41pm
Hi Stoyan,
I am updating to version 2.2.1. and in the process noted that CopyToClipbord of the diagram will not restore custom DiagramLink implementation, they work fine until I use copy paste the deserialization restores the DiagramLinks instead of the custom implementation.
Do you have an idea why this is happening?
Hugo
Re: Copy to clipboard issues
Reply #1 - Oct 28th, 2009 at 6:33pm
Hi Hugo,
It should work if you override the DiagramLink.Clone method and create a copy of the link by calling your copy constructor.
hrumayor
Reply #2 - Oct 28th, 2009 at 8:59pm
Hi Stoyan,
The clone override fixed the problem.
I wonder why there is no copy constructor on DiagramLink, I had to use the one that has 2 extra parameters the origin and destination nodes.
Thank you,
Hugo
