Normal Topic Unexpected / undesired selection of links (Read 2486 times)
hrumayor
Oct 28th, 2009 at 5:48pm
Hi Stoyan,
I found a strange behavior upon selection of links, under some circumnstances ports on nodes will not be selected when clicked or on mouse over, instead of selecting the expected link other links are selected normaly close by the desired link. It seems the alogrithm that checks what node is selected is not working properly.  If the node is moved a bit normaly it starts working.
Any ideas of how to debug this issue?
Hugo
Hugo
Re: Unexpected / undesired selection of links
Reply #1 - Oct 28th, 2009 at 6:56pm
This might have something to do with the new LinkHitDistance property, try setting  it to a small value, such as 3 or 4 points.
hrumayor
Reply #2 - Oct 28th, 2009 at 7:16pm
Hi Stoyan,
It reduced the problem, but I am still getting on some links with the weird behavior, a line that is far away and should not be selected gets selected, and it is far out of the reach of the LinkHitDistance value.
Is as if there was a invisible link there.
I will try to find more about the problem.
Hugo
Reply #3 - Oct 29th, 2009 at 12:40pm
Hi Hugo,
We've found some strange results too. This version should fix that, if you had the same problem:
https://mindfusion.eu/_beta/wpfdiag_hittest.zip
hrumayor
Reply #4 - Oct 29th, 2009 at 1:54pm
Hi Stoyan,
This beta version seems to fix the problem, to what I could see no more strange ghost line selections.
Will it be long until this fix gets released?
Hugo
Reply #5 - Oct 30th, 2009 at 11:17am
A couple of weeks... You can find a version that doesn't display the beta message on the PM page, it should be stable enough.
